Hello Guest it is October 03, 2026, 11:00:23 AM
Author Topic: I wanted to show my homemade CNC.  (Read 22479 times)
« on: October 13, 2012, 06:14:37 PM »
Hello All,
Back in June I Built a CNC router made from plywood. I made the 30 x 50 work surface by creating a torsion box and topping it with a piece of white melamine. The lead screws and lead nuts are .625" 10 TPI and I purchased them from Roton.com. I used 1.25" aluminum angle and sealed 608 ball bearings for the linear rail system. The stepper motors, drives, power supply, breakout board and relay board were all purchased from Probotix.com. I am running 32 bit Windows 7 and using a wireless X-Box controller for my jog box. And finally I found a used Renishaw MP8 wireless probe for creating 3D point clouds. Total investment, including Mach 3, Vectric V-carve pro, and my bare-bones PC from tigerdirect.com, was around $3000.
The Mach 3 has proven to be very good software. It made my router build a lot easier to complete.
My router is my own personal design, However - I did a ton of research online before the build. So -Thank You- to all that have gone before me and smoothed the path to a successful router build.
-David
Re: I wanted to show my homemade CNC.
« Reply #1 on: October 13, 2012, 07:35:25 PM »
GOOD JOB, Something to be proud of.
« Reply #2 on: October 13, 2012, 09:32:05 PM »
Hi David,
   I commend you on your skills, ability and frugal approach ... BRAVO !
Your "natural" engineering would most likely have greater structural integrity than some of the all metal designs I have seen.
Job well done.
Russ
« Reply #3 on: October 14, 2012, 12:03:22 AM »
Hi David,
Job well done.
Russ
Ditto!
  •  9,374 9,374
« Reply #4 on: October 14, 2012, 03:40:59 AM »
Hi David,
Nice job - certainly a bit of sturdy construction. Thanks for showing us your build.
« Reply #5 on: October 14, 2012, 08:19:23 AM »
Great job!  I enjoy making things frugally too; it's very satisfying as well as keeping peace with 'er indoors!
One suggestion though: get some nice machine grey paint on it.  Not only will it look better but it'll reduce the wood's tendency to expand & contract with humidity changes.
Milton from Tennessee ya'll.
« Reply #6 on: October 14, 2012, 10:36:32 AM »
Nice job David! I don't recall ever seeing a ply construction as beefy as yours. Now your gonna have to show off some of your projects that come off of that machine!
« Reply #7 on: October 14, 2012, 11:40:59 AM »
Hello Again,
Thanks for all of the kind comments. I have a couple of signs to show that I am proud of. These two signs are actually for two different guy's named Donnie. Both friends from work. Also a Maple with Walnut inlay trial done with V-Carve Pro.  Enjoy.  :)
-David
« Reply #8 on: October 14, 2012, 11:57:51 AM »
Very Nice David!  You should be proud of those.
« Reply #9 on: October 14, 2012, 12:23:40 PM »
Cold beer on tap at the garage .... can't beat that !
Very nice work.
Thanks !
Russ
