Hello Guest it is November 13, 2026, 09:36:50 AM
Author Topic: mach 3 not moving the motors after the regular problems are checked.  (Read 8476 times)
Hi there
I am hooking up mach 3 to a probotix pbx-2 3 axis kit. I have set the ports and pins to probotix's specs, I have made sure the parallel port address is correct. I have checked to make sure the max nc is not turned on. I did the driver test and it is good to excellent.
The only thing I can think of is re install windows xp and mach 3.
Do any of you have any other suggestions?
Thank you,  Alonzo
Re: mach 3 not moving the motors after the regular problems are checked.
« Reply #1 on: October 11, 2012, 11:32:51 AM »
cancel that. I discovered that a probotix board will ont function if one of the drivers is shot. I unglugged the x axis on the bob and the stepper motor came to life.
