Hello Guest it is November 13, 2026, 10:10:16 AM
Author Topic: mpg  (Read 13146 times)
Offline moxy
  •  34 34
mpg
« on: October 09, 2012, 05:41:38 PM »
Hi AllI am using a 1000 line encoder in a home built MPG which works fine except.......when I stop moving the handwheel the axis starts tiny jog movements back and forth ans you can hear the stepper "singing to itself" I have tried 2 other encoders with the same result. Anyone have suggestions to fix?
Many thanks
Moxy
Re: mpg
« Reply #1 on: October 10, 2012, 01:54:00 AM »
Sounds like the issue is the encoder is stopping on a state change of the pulse and  jumping back and forth between states. MPG's usually have indents which hold the  wheel in a fixed position when stationary and that position will be away from a state change of the pulse.
Offline moxy
  •  34 34
Re: mpg
« Reply #2 on: October 10, 2012, 09:49:40 AM »
Hi Hood, Thats what I thought too so I tried a different mpg and got the same result. I'm using and old stepper with an encoder on it and the only detent I have is the normal magnetic one  of the motor. Many thanks
Les
Re: mpg
« Reply #3 on: October 10, 2012, 12:12:11 PM »
Problem with the stepper may be it has 200 indents per rev the encoder is 100 pulse per rev. So if you line up the encoder so its half way on a pulse with an indent then the next indent will make it on the edge of a pulse.
Offline moxy
  •  34 34
Re: mpg
« Reply #4 on: October 10, 2012, 03:21:02 PM »
I think you are right so I'll see if I can move the glass scale a bit and see if that helps.
Les
Offline moxy
  •  34 34
Re: mpg
« Reply #5 on: October 11, 2012, 12:42:13 PM »
I finally found the cause.........I had connected the mpg to the controller 5v instgead of the usb 5v. Swapped irt around and it's working sweetly.
Les
Re: mpg
« Reply #6 on: October 11, 2012, 03:39:37 PM »
Good to hear :)
