Hello
Guest
it is
November 13, 2026, 09:40:02 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
mpg
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: mpg (Read 13143 times)
moxy
34
mpg
on:
October 09, 2012, 05:41:38 PM »
Hi AllI am using a 1000 line encoder in a home built MPG which works fine except.......when I stop moving the handwheel the axis starts tiny jog movements back and forth ans you can hear the stepper "singing to itself" I have tried 2 other encoders with the same result. Anyone have suggestions to fix?
Many thanks
Moxy
Logged
Carnoustie, Scotland
Re: mpg
Reply #1 on:
October 10, 2012, 01:54:00 AM »
Sounds like the issue is the encoder is stopping on a state change of the pulse and jumping back and forth between states. MPG's usually have indents which hold the wheel in a fixed position when stationary and that position will be away from a state change of the pulse.
Logged
moxy
34
Re: mpg
Reply #2 on:
October 10, 2012, 09:49:40 AM »
Hi Hood, Thats what I thought too so I tried a different mpg and got the same result. I'm using and old stepper with an encoder on it and the only detent I have is the normal magnetic one of the motor. Many thanks
Les
Logged
Re: mpg
Reply #3 on:
October 10, 2012, 12:12:11 PM »
Problem with the stepper may be it has 200 indents per rev the encoder is 100 pulse per rev. So if you line up the encoder so its half way on a pulse with an indent then the next indent will make it on the edge of a pulse.
Logged
moxy
34
Re: mpg
Reply #4 on:
October 10, 2012, 03:21:02 PM »
I think you are right so I'll see if I can move the glass scale a bit and see if that helps.
Les
Logged
moxy
34
Re: mpg
Reply #5 on:
October 11, 2012, 12:42:13 PM »
I finally found the cause.........I had connected the mpg to the controller 5v instgead of the usb 5v. Swapped irt around and it's working sweetly.
Les
Logged
Re: mpg
Reply #6 on:
October 11, 2012, 03:39:37 PM »
Good to hear
Logged
Print
Pages:
1
Go Up
« previous
next »
