Hello Guest it is November 13, 2026, 11:05:03 AM
Author Topic: backlash program will not run  (Read 26793 times)
« on: January 22, 2007, 10:29:46 AM »
im useing the newest version of mach  .  it seems on every version of mach3 when i enable backlash the program stops about 5 lines down(units/measure)
i dont recall having this problem with mach2 but then i only used it for about 2 months  as soon as i uncheck the the backlash enabled button  WALA  Bertha comes back to life. I have my backlash setting set at .004   for  y,x,a this is a plasma table and i have cv unchecked and exact stop checked  i must be missing to check a box or something all help would be gretaly appreciated
John
« Last Edit: January 22, 2007, 11:24:23 AM by dgalaxy »
Re: backlash program will not run
« Reply #1 on: January 22, 2007, 04:01:03 PM »
Hey John,
    Can you post your program and xml file.
« Reply #2 on: January 22, 2007, 10:41:27 PM »
What version of mach3 are you running?
www.newfangledsolutions.com
www.machsupport.com
« Reply #3 on: January 23, 2007, 10:41:07 AM »
the newest version i just downloaded it yesterday . im sorry i havent posted the xml i just got home from work ill get it on here as soon as i wake up tonight i really appreciate you guys helping me out big time
John
« Reply #4 on: January 23, 2007, 06:03:35 PM »
here is the xml im useing it seems to do this on all my programs but as soon as i uncheck backlash  i dont have to do anything elase it just starts working
« Reply #5 on: January 23, 2007, 07:42:40 PM »
Can you post a program it is doing it with also?
Offline Chip
  •  2,055 2,055
  • Gainesville Florida USA
« Reply #6 on: January 23, 2007, 08:50:53 PM »
Hi, John
I downloaded your XML the problem is you need to change your slaved axis to C axis change the pin & port numbers and in slave Axis.
Forgot Motor tuning & Inputs C home sw also.
I ran into this problem with my waterjet cutter if I remember right.
Your probably getting good at changing things around now.
This should Doo-IT.
Hope it Helps, Chip
« Last Edit: January 23, 2007, 09:44:47 PM by afn09556 »
Offline Chip
  •  2,055 2,055
« Reply #7 on: January 23, 2007, 09:20:15 PM »
Hi, John
May have jumped in the pool no water you now ouch.
I hade-nt setup the motor tuning on C axis--------it's back----------.
In the statuss line I'm getting a Initialization Macro Called on reset, Haven't seen that before.
Still looking, Chip
« Last Edit: January 23, 2007, 09:27:40 PM by afn09556 »
Offline Chip
  •  2,055 2,055
« Reply #8 on: January 24, 2007, 12:57:04 AM »
Hi, John
I worked on this for some time, probably something in the your XML, the best is to copy down all your settings.
At screen Profile Create New Profile, check Default Profile Values, New Name enter your values in it.
With a different XML with backlash I could not get it to stop working.
Give it a try, Chip
« Reply #9 on: January 24, 2007, 10:26:34 AM »
Ok  im going to try it thanks guys for trying to help me
John
