Hello
Guest
it is
November 13, 2026, 09:42:15 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
Help, Gecko 540 fault
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Help, Gecko 540 fault (Read 9038 times)
olebandit61
12
on:
October 06, 2012, 10:11:00 PM »
Hey ,
I am using Gecko 540, I had everything set up and running on my
Kitchen
table...was running fine...checked it today before moving everything to my machine and it has gone crazy.....I rechecked all the settings and could get no movement on the X axis...but the Gecko is in fault and I can't get it out...I have unhooked everything except the power supply and the Estop and powered it up and it is still in fault...Help.
Last Edit: October 07, 2012, 04:43:00 AM by Chaoticone
Logged
Jeff_Birt
1,107
Re: Help, Gecko 540 fault
Reply #1 on:
October 07, 2012, 11:41:45 AM »
The G540 expects a chargepump signal from Mach. If it does not see that signal the fault light will not go out. You can bypass the charge pump function with the switch on the G540 marked 'Chargepump'.
Logged
Happy machining , Jeff Birt
Check out
www.soigeneris.com
Print
Pages:
1
Go Up
« previous
next »
