Hello Guest it is November 13, 2026, 05:20:23 PM
Author Topic: Two buttons doing same thing, possible?  (Read 36703 times)
« on: September 27, 2012, 09:27:50 PM »
I have kbd48cnc keyboard, and on my control panel I also have external cycle start and feed hold buttons.
When I assign the oem code 1000 to cycle start button on pin 38 the cycle start button stops working on kbd48cnc, and same with feed hold. Is there a way to have both working?
Appreciate the help,
Offline NeoTO
  •  504 504
    • PoLabs
Re: Two buttons doing same thing, possible?
« Reply #1 on: September 28, 2012, 03:23:43 AM »
Hi
We will check that and make it work. Both should work, but they might be 'fighting' each other at the moment.
Matevž
« Reply #2 on: September 28, 2012, 09:46:28 PM »
Thanks, that would be really nice :)
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: September 30, 2012, 05:44:14 AM »
There is a simple fix. Use the 'inverted' option in the mapping settings. It will also activate the function as soon as you depress the button (assuming you have connected it between PoKeys pin 38 and GND).
« Reply #4 on: October 20, 2012, 07:53:34 AM »
Finally got around to testing the set up, still not working, with invert checkbox checked only the external button is working
« Reply #5 on: December 15, 2013, 08:45:13 PM »
Any resolutions for this? Really need to get this working.
« Reply #6 on: December 16, 2013, 06:03:09 AM »
link the  kbd48cnc buttons to a user led instead to cycle start / feed hold
lets say when you press cycle start ULED 2000 turned on
the same thing with your external button, lets say ULED 2001
now create a brain thats  doing a cycle start when one of or both went on.
Or just wire the external button to the same pin to kbd48cnc button ( if that is possible )
just a thought
alex
« Reply #7 on: December 16, 2013, 10:15:51 AM »
just a thought
alex
ha! if I would only be smart enough to do that, will give it a try later today when i'm in the shop. Tho I do have an question, would this introduce any kind of lag/delay?
Russ
« Reply #8 on: December 16, 2013, 11:02:26 AM »
Ok.., just tried making a brain, and I clueless at this, any way you could walk me thru what I need to do?
Screenshot attached, is this what I need to do?
Thanks for the help,
« Reply #9 on: December 16, 2013, 01:06:04 PM »
Yes, I think its about 100 ms
a part of it.
see pic.
take care the user led that you intend to use is not used for other operations.
alex
