Hello Guest it is November 13, 2026, 05:56:50 PM
Author Topic: Two buttons doing same thing, possible?  (Read 36714 times)
Re: Two buttons doing same thing, possible?
« Reply #10 on: December 16, 2013, 01:08:39 PM »
forgot the attachment  ;D
« Reply #11 on: December 24, 2013, 10:33:55 AM »
Alex,
I tried your solution, honestly didn't get anywhere(most likely because missed something), but what I did encounter was my Single Block stopped working, any ideas?
Russ
« Reply #12 on: December 24, 2013, 06:14:42 PM »
Russ,
go to pokeys plugin configuration. -->  kbd48cnc-->
CycleStart  --> Function= Key --> LED = 1990 --> Button = none   ( maybe inverted can't see it here )
FeedHold    --> Function= Key --> LED = 1992 --> Button = none   ( maybe inverted can't see it here )
Pin***   --> Function= Input --> LED = 1991 --> Button = none --> inverted      ( external Cycle Start button )
Pin***   --> Function= Input --> LED = 1993 --> Button = none --> inverted      ( external Feed Hold button )
is working fine here so far, accept I have no  kbd48cnc.
see pict. of the brain I used
Alex
« Reply #13 on: January 02, 2014, 02:35:52 PM »
Thanks! Seems to work good now with both buttons operating correctly. Have not tested Single Block yet however.
Got another question also, probably wrong section for it, but its same thing, i have buttons connected thru pokeys56u, and i would like to be able to jog with them same way you can with arrow keys/pg up/down, but only way it works right now if you press button the table moves by itself until you press button again, which is not very safe, i want  it to move only when button is pressed. Any idea what # button to use for these?
Russ
« Reply #14 on: January 03, 2014, 12:57:36 PM »
Glad you got it so far :)
to see if is something wrong in your Pokeys settings regarding the Single Block just save your actual Pokeys settings ( XML file)
then use the default XML file from Polabs website and see if it works correctly. If so you can compare the settings.
Unfortunetly I can't load the  kbd48cnc XML file without a  kbd48cnc connected to the Pokeys so can't help with the
jogging problem. Only thing I can do from here is if you assingn all buttons ( jog +- and axis select) to an Userled then it could
be done with a brain. But first explore if there is a setting for what you need in Pokeys setup for the Jog Buttons.
maybe you can attach a screenshot.
Alex
« Reply #15 on: January 03, 2014, 04:03:38 PM »
jogging is not related to kbd48cnc, i just have 6 arcade buttons on my panel i made that are connected to pokeys directly, and would like to use two for x jogging, two for y and two for z.
« Reply #16 on: January 03, 2014, 05:09:26 PM »
ah ok,
in this case try
Pin***   --> Function= Input --> LED = none --> Button = 307 push to jog X++  --> inverted
Pin***   --> Function= Input --> LED = none --> Button = 308 push to jog X--    --> inverted
Pin***   --> Function= Input --> LED = none --> Button = 309 push to jog Y++  --> inverted
Pin***   --> Function= Input --> LED = none --> Button = 310 push to jog Y--    --> inverted
Pin***   --> Function= Input --> LED = none --> Button = 311 push to jog Z++  --> inverted
Pin***   --> Function= Input --> LED = none --> Button = 312 push to jog Z--    --> inverted
is working here
Alex
« Reply #17 on: January 03, 2014, 05:29:39 PM »
can it be that your buttons are not momentary switches ?
Alex
« Reply #18 on: January 03, 2014, 05:41:18 PM »
They are just plain arcade buttons with cherry brand micro switches, and they are momentary.
I think its how I had it set, however will check in the morning, thanks again!
- Russ
