Hello Guest it is November 22, 2026, 03:44:37 PM
Author Topic: losing steps on z-axis (help)  (Read 26549 times)
Re: losing steps on z-axis (help)
« Reply #10 on: September 29, 2012, 11:57:33 AM »
Set Mach to Sherline mode and see if that helps.
« Reply #11 on: September 29, 2012, 12:12:49 PM »
Just set this and have same job re-running to see what happens.
Attached is the g-code I have been trying to run.
« Reply #12 on: September 29, 2012, 12:17:53 PM »
By the time the job got from the right side over to the left side of the cut you can see where the finishing path was no longer touching to cut the wood. At that point it was almost 0.1 inch higher than where it originally started. There has been no consistency on where in the job it happens....
« Reply #13 on: September 29, 2012, 01:34:08 PM »
Have you tried swapping around drives or motors?
« Reply #14 on: September 29, 2012, 01:36:50 PM »
swapping around?? Unsure what you are asking??
« Reply #15 on: September 29, 2012, 01:49:38 PM »
Swap the drive from one axis to another, for example X and Z and see if the problem follows to the X or stays with the Z.
« Reply #16 on: September 29, 2012, 02:06:14 PM »
Will do after this completes. I am running the finishing cut in the gcode files I uploaded.
I did the Sherline check box you suggested and see if it does anything to improve. Will post status once I figure it out from results.
THANK YOU!!!!
« Reply #17 on: September 29, 2012, 04:32:44 PM »
That is why I asked if it was random. My guess is that  your Z can't keep up with your X & Y and it skips but not enough for it to completely go off on it's owne way. Had similar experience here when I started to do 3D cutting. Drove me bonkers, tried everything. In your case you may want to change the Z screw to the same as the X &Y and or get a different motor with more torque so the acceleration is improved.
FWIW,
« Reply #18 on: September 29, 2012, 04:57:10 PM »
Looks like what I might need to do....
Not sure but sherline setting is making a difference. Not sure if it is now going deeper than higher like before.... Will tell after next couple of jobs. right now going to let code finish running it paths for the night then start again tomorrow.
