Hello Guest it is November 13, 2026, 12:54:10 PM
Author Topic: losing steps on z-axis (help)  (Read 26485 times)
« on: September 24, 2012, 08:56:28 PM »
Hi and I would greatly appreciate some help figure out why I lose steps or that is what I think is going on with my machine.....
I have this setup
https://www.finelineautomation.com/store/show/FLA100-00
with these electronics
https://www.finelineautomation.com/store/show/EL-0007
on X & Y I have 5 start screws and on Z I have single start screw.
during a job at some point the Z thinks zero is higher than it originally starts at. X & Y are perfect.
Thanks -
Keith
Re: losing steps on z-axis (help)
« Reply #1 on: September 25, 2012, 05:43:59 AM »
Sounds like the Z is skipping steps. Experiment some, lower the max X&Y velocity.. Does this happen at a particular part of the code or is it random.
« Reply #2 on: September 26, 2012, 03:34:38 PM »
Been playing with the velocity settings like you suggested and still no fix.... :(
It is really odd - The z axis is always a bit higher at the end of the job than where it started. Where it thinks zero is changed almost every time.
« Reply #3 on: September 26, 2012, 04:20:52 PM »
What kind of work are you doing?
Post your xml file.
What is "a bit higher"?
Do you have the steps per unit set accurately for the Z?
« Reply #4 on: September 27, 2012, 03:09:23 PM »
Will post my XML when I get back home along with everything I have about my setup. Thanks
A bit higher - The bit is no longer even touching the wood it was cutting to begin with.
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #5 on: September 28, 2012, 01:15:28 PM »
Is everything clean in the Z platform/carriage? Does the ballscrew spin easily by hand (or have you checked?). I just discovered a similar problem in my mchine (and my bad technique for gib adjustment) however you appear to have linear slides so I have no idea if tension is adjustable simialr to gibs.
Offline Fastest1
  •  920 920
  • Houston, TX
« Reply #6 on: September 28, 2012, 01:16:41 PM »
Is your plunge rate set too high and loosing the steps right away?
« Reply #7 on: September 29, 2012, 11:07:54 AM »
Simple answer is YES all is good in that aspect.
« Reply #8 on: September 29, 2012, 11:09:31 AM »
No the first half of this particular job is perfect. And it is not consistent when it will start losing steps. I repeated the same job many times and it is not in same area where it loses steps.
This weekend I will be able to post some pics and my XML file.
« Reply #9 on: September 29, 2012, 11:31:13 AM »
I have this setup
Attached is my zipped up XML file...
I have played with velocity and acceleration and regardless still same problem.
I have a single start screw on Z
and 5 start on X&Y
