Hello
Guest
it is
September 15, 2026, 09:06:35 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
arc/circle move with R code
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: arc/circle move with R code (Read 12026 times)
nso
36
on:
September 22, 2012, 12:42:16 AM »
hi everyone
when i use power mill or visual mill any arc move or circle pocket create whit G01 ....
i have a few question ?
so i want create g code on whit R code how can i do and which cam software can do that?
sorry for my bad English
thanks a lot and best regard
Carnoustie, Scotland
Re: arc/circle move with R code
Reply #1 on:
September 22, 2012, 03:53:05 AM »
Sounds like your CAM is producing arcs by splitting it up into short straight moves rather than producing arcs.
As for what CAM does arcs then I would imagine nearly all, possibly it is a setting or the type of DXF you are importing that is making your CAM produce the G1's.
nso
36
Reply #2 on:
September 22, 2012, 05:18:03 AM »
hi dear hood
thanks for replay . i never ues dxf file ...always using catia for drawing and.when i want import to cam software like power mill or visual mill i chose igs that is all..
omid
Reply #3 on:
September 22, 2012, 06:43:01 AM »
Definitely sounds like its a setting in the CAM or possibly the Post Processor that is not set to use Arcs.
Hal
60
Reply #4 on:
September 22, 2012, 05:56:13 PM »
Some CAD will output the 2d arc as straight lines from a 3d model. Catia being a high end 3d modeling program maybe the caaause. I have the same issue with Inventor from time to time. It is in the arc conversition between 3d file and 2d surface.
Hal
AiR_GuNNeR
24
Reply #5 on:
September 25, 2012, 12:18:30 PM »
In Visual Mill, you need to select the Advanced Cut Parameters tab, in there you select the Perform Arc Fitting. That will convert all curves into arcs that fall withing the fitting tolerance you entered in.
Print
Pages:
1
Go Up
« previous
next »
