Hello Guest it is September 19, 2026, 08:44:32 PM
Author Topic: A few of my projects..  (Read 38066 times)
« on: September 21, 2012, 11:12:23 PM »
Hi, I'm relatively new to the CNC world but am attempting to work through that...
My first project is the retrofit of an old lathe, with the help of my brother.
My brother is a fitter and machinist so most of the work was done either by him or under his instructions.
As he put it, I'm a computer geek with delusions of adequacy when it comes to machining.
I bought the old lathe mill setup for very little because the bed and screws were stuffed.
Bought some used linear rails and ball screws and then went to my brother for help.
The spindle is either able to index or spin. It has an 8000ppr encoder with an index pulse but as yet, I haven't figure out how to program it properly.
I've done most of the wiring and it runs, just have to fit the main spindle motor and figure out how to "program" the limit switches and encoder.
This is the router I purchased recently but it came with a generic LPT  controller which I will be changing out for a USB version and again, Gecko stepper drivers.
My final project is to fix this old Zenford Zeigler. The ANCA2000 controller is stuffed but the rest of the machine/servos/linear rails are in very good condition.
It has a 24 tool  ATC. I have bought some RUTEX DC servo controller along with the 8000ppr encoders, to "re-brain" it..
Just a little bit of work ahead.
Cheers.
Re: A few of my projects..
« Reply #1 on: September 23, 2012, 01:11:37 PM »
Can you attach your images instead of linking to them as they dont seem to load or atleast not for me, I get a wee bit at the top of each then it seens to stall.
« Reply #2 on: September 25, 2012, 07:02:51 PM »
Sorry, I'm on holidays at the moment...
Will fix it up next week.
Thanks for the heads up..
Cheers.
Offline mc
  •  384 384
« Reply #3 on: September 26, 2012, 08:21:28 AM »
Looks like the server is very hit or miss.
I managed to see the pics (and saved the lathe ones for my reference!).
What linear guides are those you're using the lathe?
I'm considering converting an almost identical lathe in a similar way, and was looking at using more common Hiwin rails, however due to their height it means the carriage wouldn't then fit under the chuck. I doubt that would be an issue though, as I can't see me doing anything 6" diameter where I'd need to have the carriage under the workpeice.
I was also thinking about mounting the z-axis screw inbetween the rails.
« Reply #4 on: October 07, 2012, 03:20:50 AM »
The server was off while I was away, sorry.
Made a few changes to the server settings, let me know how it goes.
As for the rails, they are THK
I've also made a wire bender attachment for the lathe. It has a 100:1 Harmonic reduction drive and I'm using a 400-step Stepper motor
Calibrating it and doing the post processing is going to be a lot of fun..
Cheers.
« Last Edit: October 08, 2012, 08:27:16 PM by Chaoticone »
« Reply #5 on: October 07, 2012, 04:06:03 AM »
Yes. The same is here.
« Reply #6 on: October 07, 2012, 04:36:03 AM »
They are loading here but very slow.
« Reply #7 on: October 07, 2012, 06:53:37 AM »
Same here. Unfortunately, far too slow for me to wait for them.
« Reply #8 on: October 08, 2012, 07:42:14 PM »
Can I edit my original posts to attach the pictures instead of linking?
Cheers.
« Reply #9 on: October 08, 2012, 07:51:31 PM »
I don't think so.  Just make a new post with the pics and I'll edit your original.
