Hello Guest it is November 24, 2026, 11:11:24 AM
Author Topic: Allen Bradely drives to Sanyo denki motors ?  (Read 118795 times)
« on: September 21, 2012, 09:09:30 PM »
Has anyone did this hookup yet. Been a long time here since setting up any ac servos. The sanyos use a straight up commutation 120 deg hookup  abc/abc on the old servo dynamics drives but the ABs use a different sequence.  Can't wrap my head around the change in sequence to make it work.
I keep getting commutation angle errors (;-)
Re: Allen Bradely drives to Sanyo denki motors ?
« Reply #1 on: September 22, 2012, 02:48:41 AM »
What AB drives?
« Reply #2 on: September 22, 2012, 08:58:17 AM »
1398-019 's
« Reply #3 on: September 22, 2012, 11:09:47 AM »
I see part of my problem the UltraMaster software ver 1.60 I have will NOT allow one to modify the motor files. So there is no way for me to setup this drive to a custom motor.
(;-( TP
« Reply #4 on: September 22, 2012, 12:15:07 PM »
Hi Terry,
Open Ultra Master Help file and look for "Setting Ultra Master Advanced Mode". This will tell you how to access the advanced features of Ultra Master. Custom motor creating is one of them.
« Reply #5 on: September 22, 2012, 12:32:54 PM »
Change the shortcut target to C:\ULTRAMST\ULTRAMST.EXE /A then open UltraMaster from that shortcut and in File menu you will see Edit Parameter Files.
If however you  do not have any commutation signals on your motor you will not get very far.
« Reply #6 on: September 22, 2012, 01:23:22 PM »
HIYA Hood yes I found your software trick with a web search. The  /A switch did the trick.
Worked out the commutation problem . Now I am trying to test with vel mode testing but I get a overspeed fault. The input field for setting the rpm will not take any values keeps sayin to enter a value between 0.0 and 0.0 .  I ener 100 but it rejects it.
Auto setup does not do anything yet(;-) Clip on start but nothing happens yet(;-)
Working on it. The AB software is strange compared to the old servo dynamics setup program (;-)
« Reply #7 on: September 22, 2012, 01:28:45 PM »
What have you got set for the RPM, see pic.
« Reply #8 on: September 22, 2012, 01:34:08 PM »
HUM I don't remember that screen anywhere. Let me check again.
« Reply #9 on: September 22, 2012, 01:38:05 PM »
Double click Drive Parameters.
