Hello Guest it is November 11, 2026, 05:45:50 PM
Author Topic: Allen Bradely drives to Sanyo denki motors ?  (Read 117846 times)
Re: Allen Bradely drives to Sanyo denki motors ?
« Reply #70 on: September 27, 2012, 04:28:15 PM »
The Top, Step + Step - Dir + Dir -
« Reply #71 on: September 27, 2012, 05:05:10 PM »
Please double check me one more time.
Is the chip the correct side up by the indent at the top?
« Reply #72 on: September 27, 2012, 05:09:51 PM »
Looks fine.
« Reply #73 on: September 27, 2012, 05:15:49 PM »
I may be wrong, but I think your view is not from the top. It is the belly view, the bottom of Hoods PCB.
Just a mirror image of the Data sheet TOP view .... I think.
Russ
« Reply #74 on: September 27, 2012, 05:16:37 PM »
This is the one I did for the Scorpion, I put Gnd connections to go to the drive, they are what the resistors are. Its supposed to be done that way but never had issues without them on the Beaver Mill which has the first style but you do want to connect the Bob Gnd to the Drives Encoder Gnd.
« Reply #75 on: September 27, 2012, 05:17:23 PM »
Russ, thats correct, the drawing TP has is the copper side of the PCB.
« Reply #76 on: September 27, 2012, 05:25:40 PM »
BTW when I said encoder Gnd on the drive I am meaning the aux encoder power common. (Pin 2 on J1)
« Reply #77 on: September 27, 2012, 06:00:55 PM »
Heard back from AB today it was a sweet sorry about your luck email and we really would like to sell you some new drives and matching motors (;-)
« Reply #78 on: September 27, 2012, 10:19:03 PM »
They are a little cheaper if you buy 100 of each. :)
« Reply #79 on: September 27, 2012, 11:41:14 PM »
Ah for the good old days when engineers at a company took pride in knowing there products inside and out. AND they took it as a challenge to PROVE they knew how to make things work.
Now it is so sorry cannot make ching ching work you need new ching.
Those days are long gone, (;-) TP
