Hello Guest it is November 23, 2026, 12:03:23 AM
Author Topic: Very new to this  (Read 11501 times)
Very new to this
« on: September 17, 2012, 11:58:16 AM »
Hi
Sorry if I'm not following proper procedure in here.
Very new to all this and forums.
Trying to test some moves on my machine.
Every time the program get to the second line of code it goes into a cutting federate mode/speed even though
the code is calling for rapid positioning.
Can anyone help.?
Re: Very new to this
« Reply #1 on: September 17, 2012, 12:13:57 PM »
Please attach the code.
« Reply #2 on: September 17, 2012, 12:20:20 PM »
G00 X25.5 Y0 Z0
G00 X35.5 Y.800 Z0
« Reply #3 on: September 17, 2012, 01:29:30 PM »
Ok please attach your xml as obviously the G0 should be such and I can think of no reason Mach would do anything else but a G0.
« Reply #4 on: September 17, 2012, 11:55:07 PM »
Thank you for taking the time to help with this.
I'm not sure what it is that you are asking for
What is the xml?
« Reply #5 on: September 18, 2012, 01:51:04 AM »
The xml is the file that contains your config settings. If you open Mach you will see the name of the profile lower right. Look in the main Mach3 folder for a file of that name with a xml extension, copy it to the desktop and then rename to shockwavefx.xml then use the additional options button on the reply page to attach to the forum.
