Hello Guest it is October 25, 2026, 02:51:53 AM
Author Topic: Manual Calibrate Spindel  (Read 7083 times)
« on: September 17, 2012, 11:47:55 AM »
Is it possible to calibrate spindle in manual mode?
-Set  S(rpm)
-Measure voltage at the output of the converter then the PWM to 0-10V
-RPM value  =Output voltage * 40Hz(For spindel  24000rpm max) * 60
-Wrote down the value in the table. Click Next Measure.
It can accurately calibrate the output voltage is controlled by the spindle speed.
Сan be such already in mach3?
Best regards, Sergey
« Last Edit: September 17, 2012, 11:54:25 AM by cncstep »
