Hello Guest it is November 13, 2026, 10:02:20 AM
Author Topic: Shuttle pro v2 steps  (Read 11477 times)
Offline faby
  •  74 74
« on: January 18, 2007, 04:32:29 AM »
Hi there i have a Shuttlepro v2 as pendant, when I turn the center wheel as single step mode, it produces at most 5-6 pulses per second, and it move so slow.
I have only mach3 plugin installed to drive the shuttlepro, no other software and I'm using the 2.037 version.
It's normal or it could generate more pulse/sec?
Thanks to all
Faby
Re: Shuttle pro v2 steps
« Reply #1 on: January 18, 2007, 07:25:04 AM »
We do this because we don't want to miss steps.... If every one ran servos with Accels set at 150in/sec^2 we could give you the faster rate :)
Sorry
Brian
www.newfangledsolutions.com
www.machsupport.com
Offline faby
  •  74 74
« Reply #2 on: January 18, 2007, 07:35:05 AM »
ok thank you..
it was not a problem only a curiosity...  ;)
Faby
« Reply #3 on: January 18, 2007, 09:45:39 AM »
No problem!
www.machsupport.com
