Hello Guest it is November 13, 2026, 10:00:26 AM
Author Topic: mach3 and pci express slot  (Read 20388 times)
« on: September 07, 2012, 01:47:35 AM »
hello
i use a laptop(with pci express slot)for my cnc but i don't know why lpt port doesn't work
its my device manager info:
thanx
Re: mach3 and pci express slot
« Reply #1 on: September 07, 2012, 01:50:07 AM »
i tried 4ff8 and 4ff0 but they don't work too
« Reply #2 on: September 07, 2012, 05:36:16 AM »
First off Laptops may be problematic so they are not officially supported.
What operating system are you using? Is it 32 or 64bit?
Offline docltf
  •  354 354
« Reply #3 on: September 07, 2012, 10:39:47 AM »
I didn't see the Mach3 driver listed in the devices.
bill
« Reply #4 on: September 08, 2012, 08:34:44 AM »
i use win7 64x
and what is that?
and thank you for your help
« Reply #5 on: September 08, 2012, 08:43:01 AM »
i use win7 64x
That is why it wont work, Mach parallel port driver will not work with 64Bit OS's, only 32bit. If you want to use Mach with a 64Bit OS then you will need to use one of the external controllers (PoKeys, SmoothStepper, CSMIO, DSPMC etc etc)
and what is that?
It is the Mach parallel port driver but as explained above it wont install for you and that is why I asked what OS you had ;)
« Reply #6 on: September 10, 2012, 02:00:27 PM »
it means if i use xp 32bit it will work
« Reply #7 on: September 10, 2012, 02:31:37 PM »
No guarantees it will work as it seems there are just some parallel port cards that wont but using a 32bit OS will allow the Mach driver to install so chances are it will work.
« Reply #8 on: September 11, 2012, 05:10:03 AM »
thank you
and an other question
which i/o range i must chose ?
« Reply #9 on: September 11, 2012, 05:30:10 AM »
4FF8 would be it.
