Hello Guest it is November 11, 2026, 11:14:02 PM
Author Topic: Motors does not respond! HELP!  (Read 26502 times)
« on: September 01, 2012, 09:57:30 AM »
Hi guys!
I have problems with motors on my CNC machine. When i press button RESET i hear motors how they working but when i try to move they not respond. In Mach3 show me how coordinates are changing but my machine stay in place. In past this machine was working correctly and after reinstalling system on PC i have this problem. I can post pictures of settings if that can help.
PS. Sorry for my english :)
Thank you Milan.
Re: Motors does not respond! HELP!
« Reply #1 on: September 01, 2012, 04:43:21 PM »
Attach your xml and I will have a check of your config to see if there is an obvious issue.
« Reply #2 on: September 02, 2012, 09:19:44 AM »
Step Port and Dir Port was on ''0'' and i set on ''1'' but then only Z axis work. Another two X and Y does not work.
There is picture of configurations. http://www.sendspace.com/file/prm3vh
Thank you Hood for reply.
« Reply #3 on: September 02, 2012, 09:22:30 AM »
I need your xml so I can check it as there could be a lot more than just what you have in pics.
« Reply #4 on: September 02, 2012, 11:28:45 AM »
There is my xml..
« Reply #5 on: September 02, 2012, 01:46:16 PM »
What version of Mach are you running?
What is the Time in Int and the Frequency on the Diagnostics page?
Are you using the onboard parallel port or have you got a PCI parallel port?
« Reply #6 on: September 03, 2012, 02:52:02 AM »
Version of Mach is 3.
Times vary between +4.1 and +5.9 and Pulse Frequncy is 23692.
I use onborad parallel port (LPT1).
« Reply #7 on: September 03, 2012, 04:07:57 AM »
I was meaning the actual version of Mach 3 you will see that from the Help menu then the About Mach.....
Looking at your config it seems ok as long as you have the correct pins set for each axis. There is one thing however, Looking at your motor tuning I would guess you are meant to be using metric units but you have the default set to Inch. If that is the case then go to Config menu then Native units and change to metric. With your settings in motor tuning and Mach thinking its incch your will likely stall very quickly, if not instantly.
« Reply #8 on: September 03, 2012, 05:17:24 AM »
How i see verison of the Mach is 1,02. I did how you said but X and Y axis still can`t run.
Do you know some ways how to check my driver? Maybe is driver in damage...
« Reply #9 on: September 03, 2012, 06:39:24 AM »
1.02?
What kind of driver?
