Hello Guest it is November 13, 2026, 12:51:46 PM
Author Topic: Bad Character Line 0  (Read 10435 times)
« on: August 29, 2012, 09:34:37 PM »
When i create a file in Bobcad V24 and go to load it into Mach 3, everything looks to post correctly but when i hit regen toolpath i get an error code of Bad Character line 0. the g codes start with N01, i noticed others in the forum start with N00. Is this the problem? Is this Mach 3 problem or a Bobcad problem? The file is saved correctly as an NC file with .tap and appears to be fine until i load it to Mach 3. Also the diagram does not show up like with my original text square?
thanks marvin
Re: Bad Character Line 0
« Reply #1 on: August 29, 2012, 09:54:59 PM »
Something in your first line of g-code is invalid as far as Mach3 is concerned.
Post the entire first line.
N01 is NOT the problem.
« Reply #2 on: August 29, 2012, 10:26:03 PM »
How do i post the first line when the line Noo doesnt appear in bobcad or when transffered to mach3.
« Reply #3 on: August 29, 2012, 10:41:08 PM »
can open in notepad, copy /paste
John
