Hello Guest it is November 13, 2026, 04:58:11 PM
Author Topic: Pokeys 56U pulse engine  (Read 16439 times)
« on: August 27, 2012, 04:30:17 AM »
Hi
I plan to run a Lathe with Pokeys 56U.
Did some small tests, it worked very good but a have some small problems sure a do somthing wrong.
I run the MPG with ( lets pokeys handle MPG) .
if a run it with mouse on jog +x it go -x it works ok iif a config as paralell but when config as pokeys pulse engine it reversed,
i can change the direction on the motors , i suspect that wy softlimits not work for me.
and a can not zero X ort Z after that a turn on mpg but as long a in cont mode a can zero but not after i get into mpg mode.
What i doing wrong?
I  run Mach3 on a mill and router the last 5 years.
For the Lathe its Win XP 32 SP3, Pokeys last firmware and plugin , mach3  Version R3.043.062
Kind Regards / Hasse
Offline NeoTO
  •  504 504
    • PoLabs
Re: Pokeys 56U pulse engine
« Reply #1 on: August 27, 2012, 04:37:21 AM »
Hi, Hasse
I lost you here:
Can you explain this little more?
Matevž, PoLabs
« Reply #2 on: August 27, 2012, 06:55:28 AM »
When a want to Zero part with Button 1008: Zero X for example.
I can do that if a start with Cont mode  on the screen MPG, but when a go to MPG mode and turn the encoder,
after that a cant zero any more even in Cont mode.
The softlimit most have something to do with the direction if jog X+ it go X- in pokeys mode.
the limits and direction works for me in paralell mode?
Regards/ Hasse
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #3 on: August 27, 2012, 08:09:58 AM »
It's hard for me to decode your writing if you keep substituting I with a.
Do you have MPGs handled directly by PoKeys or do you have MPG only connected to PoKeys and Mach3 does the handling?
« Reply #4 on: August 27, 2012, 09:55:08 AM »
Hi
My Eng is very bad  ???
I build a Lathe and i have 2 pokeys as spare for my 737simulator, i have  total 7 Pokeys 56U.
If it not work a swap it to a C10 paralell no big deal, but a love this card for the sim
I made a short video clip no hiigh quality its from the phone.
http://www.youtube.com/watch?v=91kjtNih7HQ
« Last Edit: August 27, 2012, 10:10:40 AM by hassse.w »
Offline NeoTO
  •  504 504
    • PoLabs
« Reply #5 on: August 27, 2012, 01:29:06 PM »
We will check this and will let you know.
