Hello Guest it is November 13, 2026, 05:43:13 PM
Author Topic: not responding to f feed codes?  (Read 12353 times)
Offline vz58
  •  17 17
« on: August 25, 2012, 01:08:39 PM »
My computer crashed so I bought a new one.  everything works great but for some reason it does not respond to f codes.  I have to set the speed by using override on the main screen.  I has to be something simple but I cant figure it out.
i.e.  if the program says f20 it runs wide open.  if the code is f3 it runs wide open.  I can only control the overall speed on the main screen override.
Re: not responding to f feed codes?
« Reply #1 on: August 25, 2012, 02:29:33 PM »
Attach your xml and I will see if I can find the problem.
« Reply #2 on: August 26, 2012, 06:29:57 AM »
Does your code use G0's, or G1's?
Offline vz58
  •  17 17
« Reply #3 on: August 26, 2012, 10:21:43 AM »
G00.  Followed after position ing f codes
« Reply #4 on: August 26, 2012, 10:23:52 AM »
G00 are rapid moves, and are not affected by F words.
You need to program using G1 for the F words to control the speed.
« Reply #5 on: August 26, 2012, 10:24:12 AM »
G0 (G00) is a move at rapid speed the F word will not have any effect on it, you need a G1 (G01) if you want a linear feed at the specified feedrate.
Edit, Too slow ;D
Offline vz58
  •  17 17
« Reply #6 on: August 26, 2012, 11:38:32 AM »
Figured I was doing something bone headed.  Will check tomorrow.  Thanks!
