Hello Guest it is November 13, 2026, 09:41:17 AM
Author Topic: Capacitors  (Read 12794 times)
Offline kolias
  •  1,165 1,165
Capacitors
« on: August 24, 2012, 07:01:37 AM »
On the previous cnc I had, I used a Probotix BOB and Hood suggested to install a 0.1uF ceramic capacitor between the + and – where the wiring from the limit switches were connected.
I'm doing the wiring now for my new cnc and since I use the G540, is it necessary to install these capacitors on the wiring for the limits again?
__________________
Nicolas
Nicolas
Re: Capacitors
« Reply #1 on: August 24, 2012, 08:25:02 AM »
Try without, you only need to insatll caps if you have a noise issue and I cant recall anyon needing them with the G540.
Re: Capacitors
« Reply #2 on: August 25, 2012, 06:54:22 AM »
I can confirm Hood is correct in that I use the G540 on my Taig Lathe and do not need any caps on my limit switches.
Offline kolias
  •  1,165 1,165
Re: Capacitors
« Reply #3 on: August 26, 2012, 11:53:14 PM »
Thank you both, I will try without the caps
Nicolas
Re: Capacitors
« Reply #4 on: August 27, 2012, 04:54:00 AM »
Interesting.  I am having noise issues with my limits.  I do not want to let the smoke out of my BOB so please explain the wiring of the cap.
Re: Capacitors
« Reply #5 on: August 27, 2012, 05:56:35 AM »
Much better to have your limit wires properly shielded and grounded if you dont already but if caps are needed then usually its a 0.1uF cap that is used and it connects between the input and a gnd pin/
Re: Capacitors
« Reply #6 on: August 27, 2012, 08:33:39 AM »
Agreed, just to be clear, I always use shielded cable on the home/limit switches.
