Hello Guest it is October 21, 2026, 03:13:02 AM
Author Topic: M Codes  (Read 9106 times)
M Codes
« on: August 06, 2012, 02:35:04 PM »
I am using plasma for the first time.  I have to fire the torch manually in the Mach screen.  I expected it to toggle to the start point and fire automatically when it hit the start point of the design.
Instead I have to fire it and it drags over to the start point and starts it's code run.
Does anyone know the M Codes I need to generate to fire at the start point? Is there something else I might be missing?
Am I right or wrong on it firing at the start point of the design on it's own?
Only one way to Get-er-Done......Do-er-Right!
Re: M Codes
« Reply #1 on: April 15, 2013, 07:51:47 PM »
I am having the same problem. Did you ever find a solution?
Re: M Codes
« Reply #2 on: April 15, 2013, 11:03:01 PM »
Sorry I missed this, you will find a lot of information by going to the link below and doing a search for THC.
http://www.machsupport.com/docs/Mach3Mill_Install_Config.pdf
