Hello Guest it is November 11, 2026, 06:18:11 PM
Author Topic: startup screen smoothstepper or normal printerport operation  (Read 11656 times)
Offline tantan
  •  130 130
« on: August 06, 2012, 12:38:55 PM »
hi all,
when i start mach, i used to become a dialogscreen where i could select if i want to use the smoothstepper or normal printer port operation. i still get the screen in turn but not in mill. can i switch it on again somewhere in mill?
tnx,
tantan
Re: startup screen smoothstepper or normal printerport operation
« Reply #1 on: August 06, 2012, 12:47:39 PM »
Function Config menu then choose Reset Device Select. You will now get the selection next time you start Mach.
Offline tantan
  •  130 130
« Reply #2 on: August 07, 2012, 06:36:18 AM »
Spot on hood, tnx!
Tantan
