Hello Guest it is November 13, 2026, 06:41:03 PM
Author Topic: Large circles in g-code...  (Read 8920 times)
« on: August 04, 2012, 07:04:14 PM »
hello everyone,
Well I'm back with another problem...
I posted g-code using a trial version of Vectric Cut3D using a sample file supplied with the software that was supposed to allow you to save the tool path to g-code.  When I load the g-code file using Mach3 several large (magenta) circles appeared in the g-code preview window.   looked like these large circle were actually short circular segments between points A and B that went around in the opposite direction from point B to point A.
What do you think?  Does anyone know what caused them?
Dale
Re: Large circles in g-code...
« Reply #1 on: August 04, 2012, 07:29:50 PM »
Change your IJ mode to incremental
« Reply #2 on: August 04, 2012, 10:40:43 PM »
Gerry,
Thanks Gerry..!!  This fixed it..!!
Dale
