Hello Guest it is November 11, 2026, 06:30:06 PM
Author Topic: Using port 3 as generic IO  (Read 11414 times)
« on: August 01, 2012, 08:11:13 AM »
I want to use pins 1A, 1B and 1I (1, 2 and 3) as generic TTL inputs. How are these ports setup? High? Low? Do they have a corresponding pull up/down resistor? The lack of proper documentation can be frustrating at times.
Thanks!
g
Offline Jeff_Birt
  •  1,107 1,107
    • Soigeneris
Re: Using port 3 as generic IO
« Reply #1 on: August 01, 2012, 10:31:06 AM »
They are just like any other input. Use them as Port 3 Pin 1, Port 3 Pin 2, Port 3 Pin 3 in Mach. They are pulled up like most other inputs on the SmoothStepper.
Happy machining , Jeff Birt
