Hello Guest it is November 13, 2026, 09:36:10 AM
Author Topic: Constant Velocity Questions  (Read 9765 times)
« on: July 31, 2012, 06:19:56 PM »
If I do a pocket cut of a rectangle, the inside corners are not "square" with the radius of the cutting tool. For example, I use 1/4" router bit so the inside corners should have 1/8" radius "fillets". On my "new" CNC router that can do 60 IPS, the inside corners have 1/2" or larger "fillets". How can I fix the problem?
Offline Hal
  •  60 60
Re: Constant Velocity Questions
« Reply #1 on: July 31, 2012, 08:29:57 PM »
Program a radius in the corners. You can program center line of the cutter or part program.
« Reply #2 on: July 31, 2012, 08:38:35 PM »
In General Config, Check Use CV on angles and set it to 89° or 90°.
The proper fix is to increase acceleration, if your machine is powerful enough.
