Hello
Guest
it is
November 13, 2026, 03:45:09 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
General Mach Discussion
NEW WITH MACH, HAVING ISSUES
« previous
next »
Print
Pages:
1
2
3
4
5
6
Go Down
Author
Topic: NEW WITH MACH, HAVING ISSUES (Read 61004 times)
Carnoustie, Scotland
Re: NEW WITH MACH, HAVING ISSUES
Reply #20 on:
July 28, 2012, 05:14:27 PM »
Ok so what is the kernel set to in Ports and Pins?
Logged
BOATDUDEGUY
41
Reply #21 on:
July 28, 2012, 05:15:35 PM »
25k
Logged
Reply #22 on:
July 28, 2012, 05:18:35 PM »
Ok so the computers frequency is way out from that setting so try seeing how it does at 35K in ports and pins.
Logged
BOATDUDEGUY
41
Reply #23 on:
July 28, 2012, 05:21:48 PM »
alright
i saw it said if kernel speed changed i must retune motors
is that true
Logged
Reply #24 on:
July 28, 2012, 05:23:21 PM »
Not really, should be fine but best to restart Mach. You are just using the parallel port I presume?
Logged
BOATDUDEGUY
41
Reply #25 on:
July 28, 2012, 05:24:21 PM »
correct
Logged
Reply #26 on:
July 28, 2012, 05:25:41 PM »
Ok see hopw it is on 35K kernel, see if frequency on diagnostics is more in line with the kernel.
Logged
BOATDUDEGUY
41
Reply #27 on:
July 28, 2012, 05:28:30 PM »
now my ports and pins are 35k and diags read 41 6k diff
previously at 25k in ports and pins diags read 33 around 8k diff
Logged
BOATDUDEGUY
41
Reply #28 on:
July 28, 2012, 05:30:05 PM »
so i changed in ports and pins to 45k and restarting mach diags read 48 much closer
Logged
Reply #29 on:
July 28, 2012, 05:31:32 PM »
Ok well might be better.
What version of Mach are you using?
What are the pulse width set to on Motor Tuning page?
Logged
Print
Pages:
1
2
3
4
5
6
Go Up
« previous
next »
