Hello Guest it is November 23, 2026, 11:16:10 AM
Author Topic: help choosing right Power Supply  (Read 13967 times)
« on: July 28, 2012, 06:43:06 AM »
Hello People,
i'm looking for Power Supply with specifications similar to this one  https://mrosupply.com/product/1011875-SolaHD-Electrical_Power_Supplies_Switching_Power_Supplies    in Europe if anyone is selling or knows where to get it in UK would be very very grateful!
Jack
Re: help choosing right Power Supply
« Reply #1 on: November 25, 2013, 12:10:35 PM »
I have  MACH 3 Interface Manual V2.0  and  USB 6 Axis Interface Breakout Board Adapter CNC MACH3 For Stepper Motor Driver.
I have 3 5V 2A Driver Board F-9-40V 6 Wire 2 Phase Stepper Motor 2 Control Mode drivers
I have 3 Astrosyn Steppers  Stepper Motor P/N 4K-1066 Type 17PM-K108-P11ST No. T4-506-04 Minebea Co., LTD. Made in Thailand
Please advise compatible power supply and sources for purchase.
I am total NEWBIE attempting to DYI a CNC Router.
Thank you for your help
Gymyg7
« Reply #2 on: November 25, 2013, 12:16:46 PM »
I'm sorry, Jack...my first time on a Forum.
I thought I was POSTING...
My sincere apologies.
gymyg7
« Reply #3 on: November 25, 2013, 05:13:14 PM »
There's hardly any specs there to compare!  What do you want to drive with it?
« Reply #4 on: November 25, 2013, 07:10:55 PM »
JOHN!  Thank you so much for responding re my plight .
My electronics IQ is decidedly left of ZERO :( to the extent that I don't even know what "specs" would imply.
I am a thorough neophyte re Forums, as well, as evidenced by my mistaken response to Member Jack Dani; although it was efficacious in that it brought a response from you, Sir.
I am pursuing an idea that may be feasible via CNC.
I need HELP desperately, but multiple attempts at the ArtSoft Website today have proven fruitless, although I did finally manage to Register only to discover, in the Help & Learning section, that PDF Download was in Chinese causing me to wonder if such Manuals and Guides, etc., are even available in English.
I did, however, find and downloaded a Mach3 Interface Manual V2.0 in English from another source which I do not recall.
I forwarded a copy of the manual to a retired Aeronautical Engineer friend, who advised that I would have issues with multiple power levels for the Breakout Interface, Drivers, and Stepper motors:
"After viewing the Mach3 Manual, you need 5 vdc for the data. It is a separate tap on the pwr. sup.  It says you need 12 vdc and a 9-40 volt variable output too. This is where it starts getting difficult. Finding what you need without having to order 2 or 3 power supplies before you find the correct one."
He also advised that I read “Electronics for Dummies,” which I have downloaded to my Kindle, and through which I am presently and laboriously plowing, but haven’t struck “gold” yet.
I have acquired the components I think I need for the mini CNC Router I want to build, with the exception of the Power Supply.
All the Tech-Types with whom I’ve spoken ask about Schematics; I’ve Googled same ad absurdum to no avail.
So I have the Mach3 6 Axix Breakout Interface, Stepper Drivers, and motors, but it all ends there without the appropriate power supply.
I am a seventy-year-old Jack of numerous and sundry trades, and master of but one: music. I am determined to follow the sagacious  resolution of a Head Master for whom I once taught, who vowed that ‘his last day on the planet would be his most productive,’ and as long as I have breath, I shall endeavor to do the same; hence the present quagmire.
I am so grateful that you responded, and would be profoundly and eternally indebted to you should there be any advise, or assistance that you might be willing to provide.
Thanks again, and I wish you and yours a blessed Thanksgiving, a merry Christmas, and a New Year that exceeds your wildest expectations.
Very truly,
Jim Guinn aka (gymyg)
« Reply #5 on: November 26, 2013, 09:12:22 AM »
Jim, is this the breakout board (BoB) you have?
http://www.ebay.co.uk/itm/like/160896548661?lpid=83&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=83&ff19=0
This is what Google came up with when I searched for your text "Mach3 6 Axix Breakout Interface".  What stepper drivers do you have?
You should need only a +5v supply for the breakout board; and (probably) a fixed supply at 30 - 40 volts for the steppers.  What is the current rating of the steppers you have got?
For the stepper supply see this:
http://www.ebay.co.uk/itm/36V-9-7A-350W-AC-DC-Universal-Regulated-Switching-Power-Supply-PSU/350858687521?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D286%26meid%3D2976572373932611043%26pid%3D100005%26prg%3D1048%26rk%3D1%26rkt%3D5%26sd%3D370888525779%26
It is possible that your BoB might need 12 volts as well - need confirmation of what sort it is first.
And this is a 5V supply (has 220V input but probably version available for 110 V).
http://www.ebay.co.uk/itm/5V-2A-10W-Regulated-Switching-Power-Supply-/330687475603?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item4cfe826f93
Note that Mach3 is purely a software product - what power supplies might be needed depends not on Mach3 but the BoB and stepper drivers.
Hope this helps!
