Mach Discussion => General Mach Discussion => Topic started by: JackDani on July 28, 2012, 07:43:06 AM
Hello People,
i'm looking for Power Supply with specifications similar to this one https://mrosupply.com/product/1011875-SolaHD-Electrical_Power_Supplies_Switching_Power_Supplies in Europe if anyone is selling or knows where to get it in UK would be very very grateful!
Jack
I have MACH 3 Interface Manual V2.0 and USB 6 Axis Interface Breakout Board Adapter CNC MACH3 For Stepper Motor Driver.
I have 3 5V 2A Driver Board F-9-40V 6 Wire 2 Phase Stepper Motor 2 Control Mode drivers
I have 3 Astrosyn Steppers Stepper Motor P/N 4K-1066 Type 17PM-K108-P11ST No. T4-506-04 Minebea Co., LTD. Made in Thailand
Please advise compatible power supply and sources for purchase.
I am total NEWBIE attempting to DYI a CNC Router.
Thank you for your help
Gymyg7
I'm sorry, Jack...my first time on a Forum.
I thought I was POSTING...
My sincere apologies.
gymyg7
There's hardly any specs there to compare! What do you want to drive with it?
JOHN! Thank you so much for responding re my plight .
My electronics IQ is decidedly left of ZERO :( to the extent that I don't even know what "specs" would imply.
I am a thorough neophyte re Forums, as well, as evidenced by my mistaken response to Member Jack Dani; although it was efficacious in that it brought a response from you, Sir.
I am pursuing an idea that may be feasible via CNC.
I need HELP desperately, but multiple attempts at the ArtSoft Website today have proven fruitless, although I did finally manage to Register only to discover, in the Help & Learning section, that PDF Download was in Chinese causing me to wonder if such Manuals and Guides, etc., are even available in English.
I did, however, find and downloaded a Mach3 Interface Manual V2.0 in English from another source which I do not recall.
I forwarded a copy of the manual to a retired Aeronautical Engineer friend, who advised that I would have issues with multiple power levels for the Breakout Interface, Drivers, and Stepper motors:
"After viewing the Mach3 Manual, you need 5 vdc for the data. It is a separate tap on the pwr. sup. It says you need 12 vdc and a 9-40 volt variable output too. This is where it starts getting difficult. Finding what you need without having to order 2 or 3 power supplies before you find the correct one."
He also advised that I read “Electronics for Dummies,” which I have downloaded to my Kindle, and through which I am presently and laboriously plowing, but haven’t struck “gold” yet.
I have acquired the components I think I need for the mini CNC Router I want to build, with the exception of the Power Supply.
All the Tech-Types with whom I’ve spoken ask about Schematics; I’ve Googled same ad absurdum to no avail.
So I have the Mach3 6 Axix Breakout Interface, Stepper Drivers, and motors, but it all ends there without the appropriate power supply.
I am a seventy-year-old Jack of numerous and sundry trades, and master of but one: music. I am determined to follow the sagacious resolution of a Head Master for whom I once taught, who vowed that ‘his last day on the planet would be his most productive,’ and as long as I have breath, I shall endeavor to do the same; hence the present quagmire.
I am so grateful that you responded, and would be profoundly and eternally indebted to you should there be any advise, or assistance that you might be willing to provide.
Thanks again, and I wish you and yours a blessed Thanksgiving, a merry Christmas, and a New Year that exceeds your wildest expectations.
Very truly,
Jim Guinn aka (gymyg)
Jim, is this the breakout board (BoB) you have?
http://www.ebay.co.uk/itm/like/160896548661?lpid=83&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=83&ff19=0 (http://www.ebay.co.uk/itm/like/160896548661?lpid=83&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=83&ff19=0)
This is what Google came up with when I searched for your text "Mach3 6 Axix Breakout Interface". What stepper drivers do you have?
You should need only a +5v supply for the breakout board; and (probably) a fixed supply at 30 - 40 volts for the steppers. What is the current rating of the steppers you have got?
For the stepper supply see this:
http://www.ebay.co.uk/itm/36V-9-7A-350W-AC-DC-Universal-Regulated-Switching-Power-Supply-PSU/350858687521?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D286%26meid%3D2976572373932611043%26pid%3D100005%26prg%3D1048%26rk%3D1%26rkt%3D5%26sd%3D370888525779%26 (http://www.ebay.co.uk/itm/36V-9-7A-350W-AC-DC-Universal-Regulated-Switching-Power-Supply-PSU/350858687521?rt=nc&_trksid=p2047675.m1851&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D286%26meid%3D2976572373932611043%26pid%3D100005%26prg%3D1048%26rk%3D1%26rkt%3D5%26sd%3D370888525779%26)
It is possible that your BoB might need 12 volts as well - need confirmation of what sort it is first.
And this is a 5V supply (has 220V input but probably version available for 110 V).
http://www.ebay.co.uk/itm/5V-2A-10W-Regulated-Switching-Power-Supply-/330687475603?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item4cfe826f93 (http://www.ebay.co.uk/itm/5V-2A-10W-Regulated-Switching-Power-Supply-/330687475603?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item4cfe826f93)
Note that Mach3 is purely a software product - what power supplies might be needed depends not on Mach3 but the BoB and stepper drivers.
Hope this helps!
