Hello Guest it is November 13, 2026, 07:43:49 PM
Author Topic: Drag Knife  (Read 11259 times)
Drag Knife
« on: July 27, 2012, 12:04:17 PM »
I know mach 3 has a macro for using a C axis drag knife.  Why question is if you are cutting a start shape.  All the video's I've seen show cutting profiles like an ellipse or arc.  What happens when you cut straight lines at different angles.  Will the C axis align with the cut for each line of a star.  Tool up over down, cut line, up rotate down cut line etc etc.
Any information on this would be great.
Re: Drag Knife
« Reply #1 on: July 27, 2012, 01:51:47 PM »
I think you are referring top a tangent Knife function not a drag knife. The drag knife is free floating for rotation. The tangent is axis controlled and follows the direction of XY movement.
Just a thought, (;-) TP
Re: Drag Knife
« Reply #2 on: July 27, 2012, 02:05:28 PM »
You are right
