Hello Guest it is November 13, 2026, 02:10:19 PM
Author Topic: Spindle parking (more moog madness )  (Read 9637 times)
Offline otpco
  •  48 48
« on: July 20, 2012, 06:06:45 PM »
Hi all I need some ideas for mu moog project . I need to park the spindle at a n exact rotational spot . Maybee adding another  optical index sensor and somehow hooking it to the VDF and doing a jog or something .I am fishing for ideas thanks mark
Re: Spindle parking (more moog madness )
« Reply #1 on: July 21, 2012, 12:34:23 PM »
Probably the easiest way would be to use a shot pin of some sort if you can mount such a thing. You would rotate the spindle slowly and release the pin and whan it came round to the hole it would pop in and lock the spindle. You could have a limit switch to show when it was engaged (and disengaged) and that could then be used to stop the VFD.
« Reply #2 on: July 21, 2012, 06:53:35 PM »
Otpco. Which moog do you have?   I am starting on a b-22
Steve
Offline otpco
  •  48 48
« Reply #3 on: July 21, 2012, 07:20:00 PM »
hi steve no idea but an early one have been working on it for years . have taken heaps of scrap away ! mine is green . and a Q@C30 taper 25 turret tool changer ,now servoes all round .vfd drive no vari belt ( thank god) just looking intp the tool changer .its a bag of worms i can change it via switches just getting into how to automate it . Drawbar works on air using all the original bits but no oil
