Hello
Guest
it is
October 24, 2026, 11:43:08 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
C3 - Index Pulse Card
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: C3 - Index Pulse Card (Read 12738 times)
PerEklof
20
on:
July 03, 2012, 02:34:20 AM »
Hi!
I just bought the C3 - Index Pulse Card and I will use it to get the index pulse from the spindle.
But how do get the signal to Mach3??
In the manual to C3 it says:
"Easy connections. Just put the Photo-Transistor in place, connect the board to the power supply, and attach the signal output to an input pin from the parallelport."
Can I just open the cover to the parallelport-cable and use a free pin and set the correct pin in Mach3?
My controller,
http://www.optimum-machines.com/products/cnc-pc-controls-complete-and-adapter-kit/6/cnc-controller-iii-and-vi/index.html
, has no input pins.
Regards
Per
Graham Waterworth
2,785
Yorkshire Dales, England
Re: C3 - Index Pulse Card
Reply #1 on:
July 03, 2012, 05:00:12 AM »
Open the box and take some pictures of the cards inside, then post them here using the 'Additional Options', we may be able to then tell you where to connect the C3 into.
PerEklof
20
Reply #2 on:
July 03, 2012, 06:29:52 AM »
Hi!
Thank you for your reply.
This is what the controller looks like inside. There are also the cards for each axis and the main power supply.
Regards
Per
Last Edit: July 03, 2012, 06:31:46 AM by PerEklof
Print
Pages:
1
Go Up
« previous
next »
