Hello Guest it is November 16, 2026, 05:08:05 PM
Author Topic: auto zero in home positions not working  (Read 7833 times)
« on: June 25, 2012, 09:40:58 AM »
Hi I have auto zero turned on in homing limits settings but yet when the machine goes to home position it does not zero the numbers out any ideas why ? Thanks Gary
Re: auto zero in home positions not working
« Reply #1 on: June 25, 2012, 10:09:18 AM »
You are likely viewing the wrong Coord system.
Homing is in Machine Coords.
You must select Machine Coordinates to see that it is zeroed.
If you are in Mach coords, you might have a Home Off value entered which would show in the DRO.
Russ
