Hello Guest it is October 21, 2026, 02:03:36 PM
Author Topic: DrilMasterV1.01  (Read 54217 times)
DrilMasterV1.01
« on: June 20, 2012, 12:07:05 PM »
Here is a Conversational Drilling Wizard. It does several functions including Manual , Gcode creation AND reverse Engineering.
It supports all the major drilling cycles AND Bolt circle drilling as well.
It supports FILENAME creation and on the fly Code editing as you go.
The Basic Manual is in the on screen button.
Hope you find it usefull, (;-)TP
Re: DrilMasterV1.01
« Reply #1 on: June 20, 2012, 03:03:57 PM »
Russ Found a Bug here is the corrected version.
Re: DrilMasterV1.01
« Reply #2 on: June 20, 2012, 05:12:49 PM »
Hey TP, looks like a winner and thanks for posting.   :)
How about one for the lathe? You remarked that you were looking for some work..... ;) >:D
Maybe take a look at the the Drilling lathe macro in here which also provides for offsetting the X axis and drilling additional holes on the lathe other than just on center. I better explain some...one configures the lathe head as a rotary ( or manualy index the head to an angle of rotation)  and then using a drill mounted on the carriage the different dilling cycles are done. So the wizard could be both conventional along with a  specialty function.
« Last Edit: June 20, 2012, 05:23:59 PM by RICH »
Re: DrilMasterV1.01
« Reply #3 on: June 21, 2012, 11:52:51 AM »
So you want a drillmaster for a LATHE ?  To do center and OFF center drilling with a live axis (X)
Re: DrilMasterV1.01
« Reply #4 on: June 21, 2012, 03:45:03 PM »
You got it right TP. Z axis provides the depth moves and X axis provides for on or offset drilling.
Re: DrilMasterV1.01
« Reply #5 on: June 21, 2012, 05:09:51 PM »
Do you want it all in Machturn ? Or can I use MachMill (;-) Do you want a wizard or added to the turn screenset.
You do know that LES has that working in Scam (;-).
How about a Turn version of Copy Cat ? I call it SpinCopy . I worked on it for doing Spin forming and it is used to COPY the object to be spin formed.
« Last Edit: June 21, 2012, 05:24:22 PM by BR549 »
Re: DrilMasterV1.01
« Reply #6 on: June 21, 2012, 05:35:30 PM »
Here is the screen from SpinCopy.
Re: DrilMasterV1.01
« Reply #7 on: June 22, 2012, 04:09:45 AM »
Machturn would be first choice and as a wizard.
Not aware of Scam..... can you provide a link or some info?
SpinCopy sounds interesting. I use CopyCat (not  a lot but it is slick) and there is a manual for the mill version in Member's Docs.
So it only generates the profile and dosen't provide pathing for machining?
Re: DrilMasterV1.01
« Reply #8 on: June 22, 2012, 11:57:45 AM »
Scam = SheetCam
Re: DrilMasterV1.01
« Reply #9 on: June 22, 2012, 05:08:37 PM »
Rich would something like this do ?
