Hello Guest it is September 01, 2026, 03:20:42 PM
Author Topic: Script Editor Font Too Small  (Read 33777 times)
Re: Script Editor Font Too Small
« Reply #10 on: June 18, 2012, 12:25:45 PM »
Asked Art earlier this afternoon and the only thing he could think of was windows font size. I had previously tried that here but I only saw Normal and bigger and huge or something like that :D. No smaller.
« Reply #11 on: June 18, 2012, 12:29:29 PM »
Same here Hood, thanks tho.
Thanks Terry !
The available font settings here are Normal, Large and Extra Large.
It's allways been on Normal.
I tried Large, it works as it should for all of Windows but the Editor never changes .... still too dinky to read very well.
The DRO's and everything else in Mach are normal with the exception of the Gen Config is larger than it was earlier.
(I dont use Auto Screen Enlarge, I prefer the smaller size)
I tried all different screen resolutions and reloaded Mach 2.61 from a disc. No change in the dinky font editor.
Changed the Hardware Accell too, no diff.
Thanks again TP,
Russ
« Reply #12 on: June 18, 2012, 12:32:40 PM »
Function Cfg.
Fonts are all as original, 18.
The Editor is not on that list tho.
Russ
« Reply #13 on: June 18, 2012, 12:38:06 PM »
WhatVersion of MACh3 are you running. WE WILL FIND YOU a solution(;-)
« Reply #14 on: June 18, 2012, 12:41:58 PM »
R3.043.022
Thanks.
Also went from Classic to XP Style then back, changed font size ... same prob.
Russ
« Reply #15 on: June 18, 2012, 12:48:23 PM »
Ok just talked to Brian, press Ctrl key and hold then scroll your mouse wheel ;)
« Reply #16 on: June 18, 2012, 12:53:59 PM »
Well I can make it bigger that way but doesnt go smaller, still worth a shot though .
« Reply #17 on: June 18, 2012, 01:00:35 PM »
Russ is there another computer near that you could just load up Mach3 on and check the fonts size in the editor?  It could be a video card /Driver issue.
Maybe Update your current video driver???
Just a thought, (;-) TP
« Reply #18 on: June 18, 2012, 01:01:16 PM »
Well no luck with that, just defaults back to standard size when you open the next time :(
« Reply #19 on: June 18, 2012, 01:12:38 PM »
OK,
Right clk on Dsktp
Properties
Settings
Advanced
DPI was on Normal(96)
Changed to 120 and the Editir font got bigger ... but so did everything else, including the DRO's .... no good.
I was looking at the font size under the Apearance tab earlier, thought that is where TP meant.
It is still on NOrmal but now Normal is as big as Large was earlier.
This has been fine on this PC for a long time, changed nothing that I'm aware of.
Have 2 other PC's in the shop which display fine. One is identical to this one.
Locked up when rebooting from DPI change earlier, will try to set it bac to 97, then check in later.
The scroll wheel seems to work but like Hood says, doesnt "stick".
Thanks again,
Russ
