Hello Guest it is November 23, 2026, 07:09:11 PM
Author Topic: not sure what happened  (Read 11369 times)
« on: June 12, 2012, 11:49:52 AM »
havent ran the mill for awhile so i needed to do a simple job and the machine moves half of what the dro says it moves. plus and error came up with safe Z turned off, ignoring safe z moves. not sure what changed. maybe one of you guys can point me in the right direction. thanks  tom
Re: not sure what happened
« Reply #1 on: June 12, 2012, 12:17:05 PM »
well i got the safe Z fixed. did a simple circular pocket in NF .5 dia. 200 deep .1875 endmill. dia. came to .335, .100 in depth.
« Reply #2 on: June 12, 2012, 01:22:21 PM »
Sounds to me like your steps per unit are off, Probably best place to start off.
John
« Reply #3 on: June 12, 2012, 03:15:47 PM »
you beat me to the response. i got to read in the book and reset the steps, well it took care of the prob. didnt even no it was there. i got this second hand and it was all set up. ran great for couple years and then this happens. so i guess i'll know now how to fix it if it happens again. question is why does it happen in the first place?
« Reply #4 on: June 12, 2012, 03:49:28 PM »
I'm just guessing but it could be the xml file was damaged or some such, you might want to check/confirm all your settings.
John
« Reply #5 on: June 12, 2012, 07:40:51 PM »
never looked at it so im not even sure what to look for
