Hello Guest it is September 01, 2026, 01:17:05 PM
Author Topic: Remebering settings  (Read 12661 times)
Remebering settings
« on: June 11, 2012, 03:49:03 PM »
 I am new to to the forum and want to thank you for posting all your great knowledge.
I have been running Mach3 for a few months now and it's been great. But I have one issue, It doesn't remember my settings when I shut down. I am wondering if it should. All my zero references get lost. Is this typical?
Re: Remebering settings
« Reply #1 on: June 11, 2012, 04:44:20 PM »
There are options lower right in General config page for persistant DROs etc. Also make sure you have the last option unchecked  (copy G54 from G59.253)
« Reply #2 on: June 12, 2012, 06:25:53 AM »
Thanks Hood,
 But it didn't work. After shutting down Mach3 and restarting all four of my zeros start with very obscure numbers. I also have to click the reset button on each startup.
Fish
« Reply #3 on: June 12, 2012, 09:12:22 AM »
You always need to click the reset when you start Mach, it is that way for safety reasons.
If you attach your xml I will take a look and see if I can find a problem with your DRO readings.
« Reply #4 on: June 19, 2012, 09:26:08 AM »
Here is my xml file. Sorry for the delay, I got distracted with other issues.
I have another question. Does Mach3 support "Inverse Time"?
« Reply #5 on: June 19, 2012, 10:34:33 AM »
General Config page lower right, choose persistent offsets.
« Reply #6 on: June 19, 2012, 11:35:49 AM »
Thanks Hood,
That worked. This will make set up much easier.
