Hello Guest it is October 21, 2026, 04:02:46 AM
Author Topic: Noob need help  (Read 32444 times)
Noob need help
« on: June 08, 2012, 03:18:01 PM »
i have a cnc 6040 bought from eBay, i bought mach3 everything installed it and everything and configured the ports and pins and the motor tuning and nothing the motors don't move neither do the dro's :( i need help asap :[
Re: Noob need help
« Reply #1 on: June 08, 2012, 04:35:06 PM »
If the DROs dont move when you jog then either your jog keys are not set up or you have Jog Control switched off or you do not actually have the axis enabled or set correctly in Ports and Pins.
If you attach your xml I will have a look.
Re: Noob need help
« Reply #2 on: June 08, 2012, 05:23:25 PM »
im not sure how to do the xtml thing and i pressed the tab and the jog screen appears and nothing.
Re: Noob need help
« Reply #3 on: June 08, 2012, 05:26:35 PM »
Look lower right when in Mach to see the name of the profile you are using. Look in the main Mach3 folder for a file with that name and a xml file extension. Copy it to your desktop and then rename it javier101.xml then use the additional options button on the reply page to attach the file.
Re: Noob need help
« Reply #4 on: June 08, 2012, 05:30:15 PM »
hopefully this works :)
-thanks
Re: Noob need help
« Reply #5 on: June 08, 2012, 05:36:07 PM »
Your xml looks fine and the DROs are working fine when I jog via the keyboard or Tab page  so not sure why they would not be working for you.
Re: Noob need help
« Reply #6 on: June 08, 2012, 05:38:00 PM »
could it be a posibility that its on windows vista?
Re: Noob need help
« Reply #7 on: June 08, 2012, 05:39:58 PM »
Ah ok, is it 64bit ? If so then yes it doesnt work on that. If using a 64bit OS you will need to use an external controller such as the Smoothstepper.
Re: Noob need help
« Reply #8 on: June 08, 2012, 05:41:08 PM »
nope its 32bit :( what could it be?
Re: Noob need help
« Reply #9 on: June 08, 2012, 05:42:39 PM »
Should be working fine then if the xml you sent is the one you are using.
Have a look on the diagnostics page and see what the Time in Int and the Frequency are.
