Hello
Guest
it is
November 13, 2026, 05:04:45 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
index sensor help please
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: index sensor help please (Read 37260 times)
joeendo
11
on:
June 05, 2012, 08:46:21 PM »
Im having trouble with the cnc4pc index card. I installed the card on my cnc converted atlas lathe trying to get rpm readout and for threading but cant get a readout and the index light in diagnostics is always on. Im not sure what im doing wrong as this is my first go at spindle index.
Carnoustie, Scotland
Re: index sensor help please
Reply #1 on:
June 06, 2012, 10:18:24 AM »
Check to see you have a low value, probably 0 ,for Index Debounce in General Config.
joeendo
11
Reply #2 on:
June 06, 2012, 06:31:41 PM »
I must have screwed something up cause the index light will come on and off randomly without me doing anything. I probably wired it wrong though I fallowed the wiring diagram and it looks right
joeendo
11
Reply #3 on:
June 06, 2012, 07:39:41 PM »
Well im getting a readout in turn but its varying wildly. It will be reading what looks like a close to actual rpm and then change going from a couple hundred to a few thousand and up.
Last Edit: June 06, 2012, 07:54:31 PM by joeendo
Reply #4 on:
June 07, 2012, 01:50:02 AM »
If you attach your xml I will have a look at your config to see if there is an issue with it.
joeendo
11
Reply #5 on:
June 07, 2012, 06:07:47 PM »
how do I do that?
Reply #6 on:
June 08, 2012, 02:06:40 AM »
You will have to copy it and rename it so that the forum will accept it, suggest you call it joeendo.xml . You can then use the additional options on the reply page to attach.
Last Edit: June 08, 2012, 02:08:13 AM by Hood
joeendo
11
Reply #7 on:
June 08, 2012, 01:39:03 PM »
hope this works
Reply #8 on:
June 08, 2012, 03:06:57 PM »
Think that is the Mach3 exe you attached instead of the xml.
joeendo
11
Reply #9 on:
June 08, 2012, 04:08:42 PM »
let me try again
Print
Pages:
1
2
3
Go Up
« previous
next »
