Hello Guest it is November 13, 2026, 04:28:46 PM
Author Topic: OneCNC to G-Code has an issue with arcs  (Read 10157 times)
« on: June 04, 2012, 01:24:08 AM »
Hello
I have been working with Onecnc for a while now for a local machine shop. The machines they have are Haas's of different types.
I made a small DIY mill some time ago and have been using Mach3 to run some programs I have written and the wizards have generated.
I'm in the process of making a bigger DIY mill so I can machine slightly bigger parts but with better finish and accuracy as the stepper motors are direct drive now not belt drive as before.
So to my problem.
When I use Onecnc to generate the G-Code Mach3 shows a line error as the pic shows.
I have used the Mach3 code generator within Onecnc but no go can anyone help with this issue.
Thanks in advance.
Tack1000
Re: OneCNC to G-Code has an issue with arcs
« Reply #1 on: June 04, 2012, 11:29:15 AM »
Either your program MISSED when it wrote the G code OR your IJ setting (inc,abs ) is incorrect.
Just a thought, (;-) TP
« Reply #2 on: August 30, 2012, 01:55:43 PM »
Switch your post setting to XYR   for your arc settings.
