Hello
Guest
it is
November 13, 2026, 01:33:06 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Z axis plunges when starting?
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Z axis plunges when starting? (Read 20399 times)
Tony G
19
Re: Z axis plunges when starting?
Reply #10 on:
June 03, 2012, 07:09:01 AM »
Thanks, I will alter those numbers later today to see what change happens. When it plunges, it is about 3/4" deep.
Tony
Tony G
19
Reply #11 on:
June 03, 2012, 10:07:48 AM »
I did the line by line cutting and line N40 was when it plunged. So I assume it is the tool offset I have not figured out correctly.
Tony
Nitromuse
53
Reply #12 on:
November 04, 2012, 09:41:05 AM »
Hi there,
Looks like you're calling G43H1 correctly, all you need to do now is be sure you've got your TLO's set correctly. We just came out with a very good setter to use, very affordable, and very accurate, best of all it's easy to use. Check it out at;
http://www.cncneeds.com/index.html
Print
Pages:
1
2
Go Up
« previous
next »
