Hello Guest it is November 13, 2026, 11:39:10 AM
Author Topic: Z axis plunges when starting?  (Read 20391 times)
Re: Z axis plunges when starting?
« Reply #10 on: June 03, 2012, 07:09:01 AM »
Thanks, I will alter those numbers later today to see what change happens. When it plunges, it is about 3/4" deep.
Tony
« Reply #11 on: June 03, 2012, 10:07:48 AM »
I did the line by line cutting and line N40 was when it plunged. So I assume it is the tool offset I have not figured out correctly.
Tony
« Reply #12 on: November 04, 2012, 09:41:05 AM »
Hi there,
Looks like you're calling G43H1 correctly, all you need to do now is be sure you've got your TLO's set correctly.  We just came out with a very good setter to use, very affordable, and very accurate, best of all it's easy to use.  Check it out at;
http://www.cncneeds.com/index.html
