Hello Guest it is October 21, 2026, 01:40:25 AM
Author Topic: We all make mistakes.  (Read 20871 times)
  •  9,374 9,374
« on: May 30, 2012, 03:20:32 AM »
I don't normally post pictures of the trash but this may be of help to others.
I recently replaced the flexible coupling on my Y Axis and everything was fine until I cut this piece (which was profiled in two passes with a 30 degree engraving point).
The new coupling was bored 1/4" and the motor shaft is 6mm - what I thought was tight obviously wasn't (but it is now  ;D ).
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: We all make mistakes.
« Reply #1 on: May 30, 2012, 09:30:58 AM »
See this is what happens if you send a boy to do a man's job  ;D ;D ;D
Ian
  •  9,374 9,374
« Reply #2 on: May 30, 2012, 10:50:28 AM »
 ;D ;D ;D
« Reply #3 on: May 30, 2012, 01:00:42 PM »
Looks perfect to me.
Sorry for the short reply but I have to rush out, have  an appointment at specsavers :)
« Reply #4 on: May 30, 2012, 09:45:42 PM »
I think you put too much demagnetism back in the coupler. I think You are getting close to creating a flux capacitor.
« Reply #5 on: May 30, 2012, 10:45:59 PM »
If it makes you feel any better, there's not enough forum space to show all the things that I have sent to the graveyard.
  •  9,374 9,374
« Reply #6 on: May 31, 2012, 01:04:30 AM »
 ;D ;D ;D
Offline rcaffin
  •  1,073 1,073
« Reply #7 on: June 01, 2012, 01:39:35 AM »
No tools actually broken?
No worries.
« Reply #8 on: June 01, 2012, 06:23:30 AM »
That's an new way to create the 3D shadow effect.
  •  9,374 9,374
« Reply #9 on: June 01, 2012, 07:47:24 AM »
 ;D ;D ;D
In many ways it was extremely fortunate (for me) that I found this problem whilst profiling engraving laminate just 2mm deep. It could have been a whole lot worse if it had happened whilst VCarving an expensive piece of Teak.  :D
