Hello Guest it is October 28, 2026, 09:46:54 AM
Author Topic: Check the hole was drilled  (Read 8086 times)
« on: May 30, 2012, 02:05:38 AM »
I am thinking about using an optical sensor to tell my machine that the hole was drilled.  I am doing a continuous drill system with a small drill bit.  I would like to know that the hole was drill and the bit didnt break off in the hole.  This would step through the subroutine in my G Code.  Is this possible?
Thanks.  Eddy
Offline stirling
  •  2,188 2,188
  • UK
    • www.razordance.co.uk
Re: Check the hole was drilled
« Reply #1 on: May 30, 2012, 02:22:01 AM »
Eddy - please do not cross post - especially numerous times. you already have an active thread for this here http://www.machsupport.com/forum/index.php/topic,20499.msg142371.html#msg142371
« Last Edit: May 30, 2012, 02:25:24 AM by stirling »
