Hello Guest it is October 21, 2026, 01:56:43 AM
Author Topic: keranla Speed & Mach locking up  (Read 23149 times)
Offline Vogavt
  •  260 260
Re: keranla Speed & Mach locking up
« Reply #10 on: May 29, 2012, 06:38:04 AM »
Hovers between 7.5 to 9.7
« Reply #11 on: May 29, 2012, 07:06:18 AM »
Yes quite high then, hopefully that was your issue.
« Reply #12 on: July 04, 2012, 07:52:19 PM »
I am tune into this and I know you seem to have to solved the issue but I have one my servos need 35000 speed to run correct numbers for length of movement. And now that I got them tuned and such the motors don't respond at all and pins whent down to2 of the lights showing on the diagnostics page
« Reply #13 on: July 05, 2012, 03:36:53 AM »
Sorry not sure what you are meaning/asking?
« Reply #14 on: July 06, 2012, 06:35:43 AM »
I figured out something to do with home switch was stopping all motor movement they where locked in but the signal from the software was blocked by the lack of pins on the parale port .the mothers are servo so they must run at 35000 to be right so to this point I got it running now I. Just need to get it dialed in an figure out home limit switches so they work /some times I am not clear because I don't know really how to word it I have never had to set the things I am setting now. It's always been just load up g code and go. You know zero the machine to e spot for the work and run g code. It is all a learning prossess for me because some of the settings I have no idea what the do if you make a new version you should lock this stuff away after it is set up.
