Hello Guest it is October 25, 2026, 11:55:24 AM
Author Topic: need help urgent  (Read 11412 times)
need help urgent
« on: May 24, 2012, 09:33:11 AM »
hI need help trying to set up motors  set port and pins for my motors y and z axis move in + and _ directions but for some unknown reason
the x axis will only move in the + direction doesn't matter how i try that is the only direction it wants to go. I did have my smoothestepper
set up but x axis wouldn't move in any direction so removed  and reset up another session but no luck im at my wits end .I have PMDX126
board and the PMDX 107 for my spindle any help would be welcome I have also tried swapping motor drivers but still get the same so motor
drivers are okay.
johnmb1946
Re: need help urgent
« Reply #1 on: May 24, 2012, 12:57:50 PM »
It will most likely be you have the wrong pin configured for the X Direction or there is a wiring issue. You can test with a voltmeter to see if the Dir pin changes between 0v and 5v depending on the direction you jog, start testing direct on the computers port and work out.
« Reply #2 on: May 25, 2012, 04:30:53 AM »
Hi tested my port pins and im getting 4.27 to 4.28 vlt on each .
john
« Reply #3 on: May 25, 2012, 04:50:40 AM »
So it is not changing as you jog?
That  would suggest you dont have them set up correctly in Mach. If you attach your xml I will have a look.
« Reply #4 on: May 25, 2012, 10:42:11 AM »
Hi Hood
i dont know if you got my XML file. I have installed on another computer
and when i reset it all up X axis works perfectly must have been a problem
with the pc it was on, it was an AMD board this one is an intel board im
running Windows XP Pro.anyway thanks for your help much appreciated
 best regards John
« Reply #5 on: May 25, 2012, 12:12:02 PM »
I didnt get the xml, not sure how you sent it.
AMD was not the problem, its the only CPU I used before I went onto the  pico and micro ATX motherboards.
