Hello Guest it is October 21, 2026, 09:14:56 AM
Author Topic: Auto Open Program  (Read 11018 times)
Auto Open Program
« on: May 24, 2012, 09:25:30 AM »
When opening Mach 3 is there anyway for it to automatically
open a specified program? This is a project for work, and the
less the user has to do, the better.
Thanks in advance
Re: Auto Open Program
« Reply #1 on: May 24, 2012, 11:27:39 AM »
You cna use the initialization function line.
Create a macro that loades the correct Gcode program, such as M2222
'M2222 Macro to autoload program
Loadfile("C:\mach3\Gcode\roadrunner.tap")  'Name of requested Gcode file
End
Then add in the Mcode to the init line in Gen/config.
When Mach3 open and you press the reset button it will LOAD the program.
« Reply #2 on: May 24, 2012, 12:14:07 PM »
Worked like a charm, Thanks BR549!
« Reply #3 on: May 25, 2012, 07:52:34 AM »
Nice, didn't realise this was possible.
I can get my operator starting runs without me now :D
« Reply #4 on: October 30, 2015, 10:16:57 AM »
I have tried this to load a g code file at start up and I get nothing. I am sure I must be missing something simple
