Hello Guest it is November 13, 2026, 12:00:42 PM
Author Topic: Noob Configuration Help  (Read 20526 times)
« on: May 23, 2012, 12:04:19 AM »
Hi folks, having some trouble and need some advise.
Just got my small 20x26 router up and running, and I'm having trouble with Mach3.
Everything worked fine with LMC2, so I'm pretty sure wiring is correct.
Issues -
1. When Jogging X and Y, axis moves in same direction when pressing +/-
2. Z axis doesn't move at all
3. Motors are screaming at me
About the drivers and build -
XYdrive XD14 bob
XYdrive XD8 drivers
Step Time - Min. 1u
Step Space - Min. 1u
Direction Hold - Min. 200us
Direction Setup - Min. 200us
Motors -
Vexta Nema 23 PK266-02A
2 Phase 1.8 /step
PSU 24v switching 12.6 amp
Acme thread 1/10 single start
Any assistance is appreciated!
Re: Noob Configuration Help
« Reply #1 on: May 23, 2012, 12:12:24 AM »
XML attached
  •  9,377 9,377
« Reply #2 on: May 23, 2012, 01:25:10 AM »
Hi Yesd0g,
I think you need to check your pin assignments for step and direction (ports and pins) also reduce your Velocity and Acceleration settings (motor tuning).
Do you have the recommended settings in your machine manual ??
« Reply #3 on: May 23, 2012, 10:36:44 AM »
Thanks Tweakie.
The machine is a home build, so no recommended settings other than the attached screen shots.  I'm pretty sure the pin assignments are right...
Here's a video of the axis running with LMC2.
http://www.youtube.com/watch?v=Bref9eKvEMM&feature=g-upl
« Reply #4 on: May 23, 2012, 10:51:27 AM »
Somewhat hard to decipher, but I believe this is the part of the XML where the motor assignments are.
<Motor0Active>1</Motor0Active>
  <Motor0DirNeg>0</Motor0DirNeg>
  <Motor0DirPort>1</Motor0DirPort>
  <Motor0DirPin>2</Motor0DirPin>
  <Motor0StepNeg>0</Motor0StepNeg>
  <Motor0StepPort>1</Motor0StepPort>
  <Motor0StepPin>1</Motor0StepPin>
  <Motor1Active>1</Motor1Active>
  <Motor1DirNeg>0</Motor1DirNeg>
  <Motor1DirPort>1</Motor1DirPort>
  <Motor1DirPin>4</Motor1DirPin>
  <Motor1StepNeg>0</Motor1StepNeg>
  <Motor1StepPort>1</Motor1StepPort>
  <Motor1StepPin>3</Motor1StepPin>
  <Motor2Active>1</Motor2Active>
  <Motor2DirNeg>0</Motor2DirNeg>
  <Motor2DirPort>1</Motor2DirPort>
  <Motor2DirPin>6</Motor2DirPin>
  <Motor2StepNeg>0</Motor2StepNeg>
  <Motor2StepPort>1</Motor2StepPort>
  <Motor2StepPin>5</Motor2StepPin>
« Reply #5 on: May 23, 2012, 10:58:37 AM »
So on the bob, the corresponding pins assignments are:
All on comms port 1
x-step  1
x-dir    2
y-step  3
y-dir    4
z-step  5
z-dir    6
x-enable 14
y-enable 16
z-enable 17
  •  9,377 9,377
« Reply #6 on: May 23, 2012, 11:26:02 AM »
Hi Yesd0g,
OK, from your information it looks like your ports and pins are configured correctly (it is just unusual to use pin1 for motor control).
Now I would try - in Ports and Pins select Sherline 1/2 pulse mode, restart and see if this makes any difference. Also make sure Kernel Speed is set to 25000Hz.
Hope this helps.
« Reply #7 on: April 14, 2014, 09:44:42 PM »
Friends, hi.
I'm from Brazil and I'd like to know were can I buy the boards :
- XYdrive XD14 bob
- XYdrive XD8 drivers
Does anybody can help me?
Thanks a lot.
Wagner
  •  9,377 9,377
« Reply #8 on: April 15, 2014, 02:54:37 AM »
Hi Wagner,
Xydrive Automation LLC are probably not the best business to try and buy from - there are much better devices available, with better support etc. Perhaps look at the CNC4PC site  http://www.cnc4pc.com/Store/osc/index.php  or the Gecko site http://www.geckodrive.com/products-order.html - both have a much better track record.
« Reply #9 on: April 15, 2014, 09:25:22 PM »
Hi Tweakie.
Thank you, but I have to do a maintanance in a machine that have some drivers from XYDrive, and I never had any problems with them, and here in Brazil it's dificult to buy them, can you help me, where do I can buy it in any shop that send them to Brazil?
Wagner
